David Matula
Strange things I see....
Discussion created by David Matula on Aug 18, 2017
Latest reply on Sep 1, 2017 by Glenn Schroeder
I am updating a part I created in 2014 in sw 2017....
some of the strange things I have seen.....
I needed to change the position on a ref sketch...I have always hated looking on the right click to find the driven dim toggle....so there was the other tab on the dim property screen.  Where I could change a dim to driving or driven I get the option to make it read only......had fun trying to undo that crazy option.
another little funny thing is that I have also seen where you can change the dim to driven in the same spot today I found read only...
The little gear where you should be able to set you system options and customize your keyboard hot keys.  Most of a week the customize was missing...till I searched for the command....now it is back.....
Not to happy with the tables and formulas
FIND AND REPLACE IN THE DRAWING...never thought about using it till they brought me 17 drawings to update some text on.  To bad the option is not there to search all 19 sheets for the text you want to change....
