How to select and name a Face
Question asked by Kei Luong on Aug 18, 2017
Latest reply on Aug 21, 2017 by Manikandan Babu
Hi everyone,
I'm writing a macro that could grab components and add mates to them in the assembly. I already have add mates to components part but still can't figure out how to grab and name the face of components. Could anyone please give me some advises.Any help is greatly appreciated and thank you so much. Below is my code attached for referencing.
' This Macro will automatically pick the faces from components and add coincident mates to the assembly
Dim swDoc As SldWorks.ModelDoc2
Dim swMate As SldWorks.Mate2
Dim ErrorLong As Long
Dim MsgReply As Integer
Dim NewAlign As Long
Dim retval As Variant
Dim swFaceName As String
Dim selFace As SldWorks.Face2
Dim swFace As SldWorks.Face2
Set swDoc = swApp.ActiveDoc
Set swAssy = swDoc
Set swSelMgr = swDoc.SelectionManager
' This part will add coincident mates to the selected entity(faces)
If swDoc.GetType <> swDocASSEMBLY Then
    MsgBox "Use this macro in Assembly documents only.", vbCritical
    Exit Sub
If swSelMgr.GetSelectedObjectCount <> 2 Then
    MsgBox swSelMgr.GetSelectedObjectCount & " items selected.  Req'd number is 2.", vbCritical
    Exit Sub
Set swMate = swAssy.AddMate3(swMateCOINCIDENT, swMateAlignCLOSEST, False, 0, 0, 0, 0, 0, 0, 0, 0, False, ErrorLong)
If Nothing Is swMate Then
    MsgBox "Mating Error #" & ErrorLong & " Mate not added.", vbCritical
    Exit Sub
If swAddMateError_OverDefinedAssembly = ErrorLong Then
    MsgReply = MsgBox("Overdefining mate.  Keep anyway?", vbYesNo + vbQuestion)
    If vbNo = MsgReply Then
        swDoc.ClearSelection2 True
        swMate.Select True
        swDoc.Extension.DeleteSelection2 0
    Else
        'swDoc.EditRebuild3
ElseIf swMate.Alignment <> swMateAlignCLOSEST Then
    MsgReply = MsgBox("Keep current alignment?", vbYesNo, "Mate Alignment")
        If swMate.Alignment = swMateAlignALIGNED Then
            NewAlign = swMateAlignANTI_ALIGNED
        Else
            NewAlign = swMateAlignALIGNED
        swMate.Select True
        swAssy.EditMate2 swMateCOINCIDENT, NewAlign, False, 0, 0, 0, 0, 0, 0, 0, 0, ErrorLong
            MsgReply = MsgBox("Flip caused errors.  Undo?", vbYesNo + vbQuestion)
            If vbYes = MsgReply Then
                swDoc.EditUndo2 1
        'swDoc.EditRebuild3
ElseIf swAddMateError_NoError <> ErrorLong Then
    MsgBox "Mate error #" & ErrorLong & vbCrLf & "Mate not added"
    If Not swMate Is Nothing Then
        swMate.Select True
ElseIf swMate.GetErrorCode <> swFeatureErrorNone Then
    Select Case swMate.GetErrorCode
        Case swFeatureErrorMateInvalidEdge
            MsgBox "Invalid edge"
        Case swFeatureErrorMateInvalidFace
            MsgBox "Invalid Face"
        Case swFeatureErrorMateFailedCreatingSurface
            MsgBox "Mate surface type not supported"
        Case swFeatureErrorMateInvalidEntity
            MsgBox "Supressed, Invalid, or Missing Entity"
        Case swFeatureErrorMateDanglingGeometry
            MsgBox "Mate geometry is dangling"
        Case swFeatureErrorMateEntityNotLinear
            MsgBox "Non-linear edges cannot be used for mating"
        Case swFeatureErrorMateOverdefined
            MsgBox "Mate is overdefining"
        Case swFeatureErrorMateIlldefined
            MsgBox "Mate cannot be solved (Ill-Defined)"
        Case swFeatureErrorMateBroken
            MsgBox "One or more entities suppressed or invalid for this mate"
    End Select
    swMate.Select True
