I just can't remember how to do it at present.
I want to be able to hide the features from the feature tree in the model in a sldprt, while the whole is still complete.
Need help jogging my memory.
Hi Scott,
You can't hide the features in a part, you could create a derived part which could be updated from your original when edits are performed or lock / break links to prevent edits having an effect. You could also export the part and import it back in.
There an some more options to do this:
- Use the "Convert to Bodies..." command in the FeatureManager
- Write an Macro wich will hide any features in the FM:
Dim swModel As ModelDoc2
Set swModel = swApp.ActiveDoc
Dim swFeat As Feature
Set swFeat = swModel.FirstFeature
Do Until swFeat Is Nothing
swFeat.SetUIState swUIStates_e.swIsHiddenInFeatureMgr, False
Set swFeat = swFeat.GetNextFeature
Loop
swModel.ForceRebuild3 (False)
When and if I share a native SW file with any one outside of my organization. I hadn't been using and had forgotten the function of defeature because I rarely share a native SW file (usually a STP or Parasolid). Ultimately, Protects IP.
Some fairly large organizations I work with have entire departments dedicated to scrubbing their engineering doc's to protect IP.
So is that to say that "Defeature" cannot be reversed then? Even if they have the software Scott?
Dave.
A valid point, Dave. The next user can run feature recognition and get whatever SW has chosen to determine the features were created. IP isn't just about the finished product but also the workflow and design process as well.
No offense to any one on the forum, if I have a method that saves myself and my company a lot of money in my workflow, I'm not likely going to share that with others. In fact, I don't even show all of my tricks to my coworkers.
The defeature tool also allows for horrible design intent to be hidden.
Don't get me wrong!
I wasn't making any criticism about your use of it, I purely didn't know anything about the feature or suitable situations whereby a person may want to use it. An educational question on my part...........
Good to know it can cover up all those extrudes I used when I should have just done a revolve lol.
Thanks Scott.
Dave.
Of Course, no criticism assumed.
I get you on hiding the extrudes and all... Sometimes we get so far into development that we might as well just leave it as a mess. As long as it can be built - hey, the drawing can cover it hahaha.
I recently did something against my own methods, and the quick and dirty would have and did taken the prize in that case. So, the right way is not always the... right way?!
It's a lot better than it was when I started all this stuff 12 months ago Jim, but still got a long way to go............. lol
Dave
You can use DEFEATURE ( Tools -> defeature ) for that.
Look what i've done with this part.
