Iam having problem with circular pattern.Shows some geomerry error.
Here is another Tip:
You can use the built in Windows Snipping tool to do better screen captures than your phone.
No matter what feature you are working with now days you need to look at all the options.....bodies features...ect...even when you mirror parts.....then look for that pesky arrow thing that comes up.....to go to the next feature manager property box. Usually the lower left hand corner of your screen will help you out with what the programs are looking for. #1 read...#2 help file If that does not help you out then ask. Took me a while to learn this. That and experiment with the options till you get the desired results.
try unchecking the geometry pattern option near the bottom.
