I can get all the components in an assembly and add them to a list:
var assembly = (AssemblyDoc)swModel; var components = (object[])assembly.GetComponents(false); var componentList = new List<Component2>(); foreach (var component in components) { componentList.Add((Component2)component); }
But I am unable to find most of the components constrained by the mates in the list:
foreach (var component in components) { var swcomponent = (Component2)component ; var mates = (object[])swcomponent.GetMates(); foreach (var mate in mates) { var swmate = (IMate2)mate; var entity1 = swmate.MateEntity(0); var entity2 = swmate.MateEntity(1); var component1 = entity1.ReferenceComponent; var component2 = entity2.ReferenceComponent; var found1 = componentList.Contains(component1); var found2 = componentList.Contains(component2); } }
My model (attached) is quite basic: the assembly contains two subassemblies (which are in fact instances of the same assembly) mated together, with each subassembly containing two parts mated together.
How can I uniquely determine which parts in the assembly each mate constrains. I need to be able to distinguish between parts that are used in different assemblies (e.g. TwoBarHinge<1>/Bar<1> should be distinguishable from TwoBarHinge<2>/Bar<1>).
I have tried comparing names, but the names that I get out of the two components for the mate don't contain the assembly when the mate is between two parts in the same subassembly. So, for example, whilst I read full names like TwoBarHinge<1>/Bar<1> when iterating through the list of components, I only read Bar<1> from the components constrained by the mate.
Thank you.
Hi Omar,
Have you looked at the following example from API help: 2017 SOLIDWORKS API Help - Get Mates and Mate Entities Example (C#)
