0 Replies Latest reply on Aug 16, 2017 1:54 PM by Kevin Reuss
    Circle to Intersection Point of Line and Object
    Kevin Reuss
      I want to set the force constraints for a Finite Element Analysis with a Macro.
      My Object is centered in the Coordinate System and I read the Forces and Positions (for 5 fingers) from a file.
      My idea was to create a Vector from the fingers position to the Center and look for intersections with my Object. That works fine, but now I have to create a new surface on this intersection point to apply a force to it. The area should have the size of a fingertip and I think a circle with the right radius will be a fair approximation.
      After the circle is created I can use the split line Function to create a new surface with the size of this circle.
      But how can I create the circle I need for this?
      Maybe the Intersection Point is on an edge.
      Is there a way to project a circle onto the surface of the object and create a surface out of this projection?
      Or do you have any other ideas?
      best,
      Kevin
