I am trying to replace the title block and revision table for a bunch of SW drawings using #TASK. Is there any way to do this if your drawings are not in the drt format?
Hi Bjorn,
I am just trying to replace the rev table with a new template. I figured out an alternative solution for that because #TASK has a macro that allows you to delete the current rev table and replace it with an existing one. I am now trying to find a way to do the same with the title block. I was trying to use the Replace Sheet Format in #TASK to replace both of those in one step, but it is not letting me use my drawings because they are drw extensions rather than drt. Just wondering if there is any way around this or another way to do it.
Hi Ryan, for the replace sheet format function, if you want to replace all the sheet formats of the drawings selected or in selected folder, type * in the find. Then point replace to your new template. The find is useful if you use different template for different part types, cnc, injection mould etc which will likely have different notes etc.
Hi Ryan,
you can replace sheet formats, but the rev table might be more difficult, especially if you wish to keep the current rev data.
EDIT:
What has changed in the rev table?
