2 Replies Latest reply on Apr 21, 2019 8:22 AM by Shivkant Tilekar
    mesh part instead of mesh assembly
    Iman Imani Moghadam
      hi. I have a question about mesh in part.
      Is it possible to mesh part separately instead of meshing assembly parts? or when we have more assembly in one assemble for simulating, is it possible to mesh and define fixtures separately for assembly parts and then insert them into simulation area for simulating hole assembly?
        • Re: mesh part instead of mesh assembly
          Ryan Dark
          Hi Iman,
          As of yet there is not a functionality that allows for you to define study parameters in a part and then insert that part and all the Simulation boundaries into an assembly.  Presently, a way you could accomplish this would be to start inside of the assembly you wish to analyze, create setups isolating the particular parts you wish to analyze while excluding all others, then re-include other parts of your assembly as you wish to then include them in your analysis.  In that way you are not duplicating efforts on fixtures, contacts, loads, and mesh controls.  You just have to start and stay at the assembly level in order to do that.
