I have been stuck on this part for a bit and tried looking threw the forums with no luck. I am trying to create a flat pattern to be sent out to water jet/laser. The surfaces do have some twist in them but I cant seem to find a solution. attached surface part files. I can send the assembly if some one will tell me how to attach?
Hi Max,
are you using SW2017? It has a surface flatten feature you can use.
Also, if you knit the surfaces, you only have to thicken once.
