JLJack Lawrence14/08/2017
Hello, I am a placement student at a skate company with a Solid Works issue.
I have produced a skate helmet model however after after checking with the factory they have asked to thicken the outer helmet dimensions by 5mm offset and maintain the inner helmet dimensions. I was wondering how to do this quickly as I have very limited time ?
A possible method I found of fixing this issue is ---
I have rolled back the model to when I had not put any holes into the helmet. I found you can offset the outer surface by 5mm to achieve a new surface. However when lofting to filling in the gap between the original outer surface and the new 5mm surface, I have small gaps between each of the surfaces.
Thankyou for all the help.
Jack
