I've got to make an alignment block to install pins on a PCB. The DXF file of the board is massive. I'm trying to clean it up by deleting the holes inside holes.
Is there a way to select entities by the dia of the circle, either in a macro or via SW menus?
Power Select:
Incidentally, Power Select stays greyed-out until there is a solid body in the file.
