CreateCornerRectangle() Method help
Question asked by John Belding on Aug 10, 2017
Latest reply on Aug 10, 2017 by John Belding
Good morning all,
The question I have is in regards to the CreateCornerRectangle() method in the SketchManager interface. I can successfully create the rectangle sketch, however, the rectangle created seems to ignore one of my Y coordinate values (almost seems to be snapping to the nearest face on the part in question).
The following lines of code are in questions:
' Ensure no selections are active before selecting the Z = 0 plane (Front Plane) as a sketch plane
swPart.ClearSelection2 True
boolstatus = swModelDocExt.SelectByID2("Front Plane", "PLANE", 0, 0, 0, False, 0, Nothing, 0)
' Create a new sketch on the now selected plane
swSketchManager.InsertSketch True
' Create a corner rectangle using the calculated Stock Body dimensions - Function ignore Z values as we are sketching on the Z = 0 plane
vSkLines = swSketchManager.CreateCornerRectangle(Round(SBDimensions(0), 8), _
        Round(SBDimensions(4), 8), _
        0, _
        Round(SBDimensions(3), 8), _
        Round(SBDimensions(1), 8), _
        0)
' Finalize sketch
The values for the SBDimension() are as follows:
  •     : SBDimensions(0) : -0.150000005960464 : Double
  •     : SBDimensions(1) : -0.171043044798851 : Double
  •     : SBDimensions(3) : 0.150000005960464 : Double
  •     : SBDimensions(4) : 0.170000001788139 : Double
  •     I have the Z values for each point set to 0 as I am sketching on the Z = 0 plane (Front Plane)
The problem is, the created rectangle has the following values for the first and second point
Upper Left corner - (-0.15000001, 0.17000000, 0) - This is correct
Lower Right corner - (0.15000000, -0.16990000, 0) - This is incorrect (Y value should be -0.17104304 as per the function definition)
Like I mentioned above, the Y value seems to be snapping coincident to the face of the part in question (when I am trying to sketch a stock body that has an offset (0.045")  from said face) - Is this the likely problem, if so, how can I work around this?
I look forward to any outside opinions on this.
Kind Regards,
Brad
