14 Replies Latest reply on Aug 11, 2017 11:12 AM by Matt Bieringer
    Save label caption on userform
    Matt Bieringer
      Hey guys,
      I have a macro that changes the label caption on my userform to match a folder that I am browsing to. Is it possible to have that caption change be permanent? I know this can be done in Excel VBA by enabling form designer with VBA, but I cannot figure out how to get that to work in Solidworks API.
      I tried to adapt the code from here: vBulletin Database Error , but I cannot get that to work.
        • Re: Save label caption on userform
          Deepak Gupta
          When you say permanent, then why can't you hard code that? And would you mind sharing the macro for someone to check the codes and suggest something?
              Matt Bieringer
              Deepak please see my reply to Simon for the code.
              Edit:
              There is a textbox on another form that changes this label, but if the other form is not called up then I want the label to remain the same as the last time a change was made to the form. This would be regardless of whether or not the initial userform and solidworks have been closed.
              Simon Turner
              I have edited that code for you:
                  Dim i As Long, n As Long
                  With Application.VBE.ActiveVBProject.VBComponents("Userform1").Designer
                      For i = 1 To .Controls.Count
                          If TypeName(.Controls(i - 1)) = "Label" Then
                              n = n + 1
                              .Controls(i - 1).Caption = "Some Label " & n
                      Next
                  End With
                  Matt Bieringer
                  Simon When I use that I get a Run Time Error 91.
                  Here is the sub where I try to save the label.
                  Private Sub CommandButton3_Click()
                  Dim strFold        As String
                  With Browse
                      .Show vbModeless
                      .StartUpPosition = 0
                      .Top = swApp.FrameTop + 300
                      .Left = swApp.FrameLeft + swApp.FrameWidth - InitForm.Width - 1200
                      .TextBox1.SetFocus
                      .Repaint
                  End With
                  strFold = Browse.TextBox1.Text
                  Label1.Caption = strFold
                  Application.VBE.ActiveVBProject.VBComponents("Initform").Designer.Controls("label1").Caption = strFold
                  ListGen
                    Matt Bieringer
                    It doesn't seem to like the .controls code for some reason. That is where I am getting the Run-Time Error '91'.
                        Simon Turner
                        I'm not sure if you can use .Controls with the name of the control. The example I gave used the index.
                        Try looping through the controls using the index to find the control with the name "label1":
                                    If .Controls(i - 1).Name = "Label1" Then
                                        .Controls(i - 1).Caption = strFold
                                Next
                            End With
                        Having said this, it is a very unusual way to achieve what you want. There is almost certainly a more standard way of doing it, such as storing the label name in a global variable in a module.
                            Matt Bieringer
                            Simon
                            Basically the label displays a folder that the user browses to. I want the label to preserve the last entry even if Solidworks has closed.
                            That being said I keep getting the Run-Time Error '91' on the .controls line, which leads me to believe that I cannot use this function. I have the VBE UI 7.1 Object Library and the Visual Basic for Applications Extensibility 5.3 as references.
                            I think I might need to do what Ivana recommended and use a txt file or something like that to save it.
                                Deepak Gupta
                                You can use an INI file or simple text file to read back the data in case you're using VB and if you're using .NET then you can store the value in the program itself..
                                    Simon Turner
                                    Or in VBA, you can use the Windows Script Host Object Model to read and write values in the registry.
                                        Deepak Gupta
                                        Agree but messing with registry is not recommended always, so didn't added that as an option
                                            Matt Bieringer
                                            Ok so I am using a simple txt file and have the writing to the file down. The issue I am having is when I go do read the data in the file and convert that to a string so I can set the caption I get a space between each character. I have tried to use a replace function but that doesn't remove the spaces.
                                            Sub ReadFile()
                                            Dim fn As String
                                            Dim txt As String
                                            Dim mtch As Object
                                            Dim m As Object
                                            fn = "B:\Files\Solidworks Files\VBA\AutoLoader\Label.txt"
                                            txt = CreateObject("scripting.filesystemobject").OpenTextFile(fn).ReadAll
                                            With CreateObject("vbscript.regexp")
                                                .Global = True
                                                .Pattern = "[^\n]+"
                                                Set mtch = .Execute(txt)
                                                For Each m In mtch
                                                    .Pattern = "[^\t]+"
                                                Next
                                            End With
                                            txt = Replace(txt, "ÿþ", "")
                                            Debug.Print txt
                                            This is what it is outputting:
                                            B : \ F i l e s \ S o l i d w o r k s   F i l e s \ V B A \
                                            It also was putting "ÿþ" at that start of the string but I was able to get that to go away.
                                                Simon Turner
                                                Seems a little complicated. I would do it more like this:
                                                Sub ReadFile()
                                                Dim fn As String
                                                Dim txt As String
                                                Dim fso As New Scripting.FileSystemObject 'Make sure you add a reference to Microsoft Scripting Runtime
                                                Dim myStream As TextStream
                                                Set myStream = fso.OpenTextFile(fn, ForReading)
                                                txt = myStream.ReadLine
                                                myStream.Close
                                                Debug.Print txt
                                                If you still get the spaces, it could be because the file is in Unicode.
                                                In that case, open it with this line:
                                                Set myStream = fso.OpenTextFile(fn, ForReading, False, 1)
                                  Ivana Kolin
                                  is it because of you want to know last used folder? I would save it in another file and read it by starting macro.
                                    Matt Bieringer
                                    Thank you everyone for the help here is the code that I have working for both the setting and the reading.
                                    Read sub:
                                    Sub ReadFile()
                                    Dim fn As String
                                    Dim txt As String
                                    Dim fso As Object
                                    Dim oFile As Object
                                    Set fso = CreateObject("Scripting.FileSystemObject")
                                    Set oFile = fso.OpenTextFile(fn, ForReading)
                                    txt = oFile.ReadLine
                                    oFile.Close
                                    'Debug.Print "1: " & txt
                                    If txt = "" Then
                                        Label1.Caption = "Folder Location"
                                    Else
                                        Label1.Caption = txt
                                    'Debug.Print "2: " & Label1.Caption
                                    ListGen
                                    Set sub:
                                    Private Sub CommandButton1_Click()
                                    Dim Path            As String
                                    Dim FileTxt         As String
                                    Dim fn              As String
                                    Dim fso             As Object
                                    Dim oFile           As Object
                                    Path = BrowseFolder(Caption:="Select A Folder/Path")
                                    If Path = "" Then
                                        MsgBox "Please select the path and try again"
                                    Else
                                        Path = Path & "\"
                                        TextBox1.Text = Path
                                        InitForm.Label1.Caption = TextBox1.Text
                                        'Debug.Print "3: " & TextBox1.Text
                                        Set oFile = fso.CreateTextFile(fn, True, False)
                                        oFile.WriteLine Path
                                        oFile.Close
