Tube Routing Question
Question asked by David Plis on Aug 9, 2017
Latest reply on Aug 15, 2017 by David Plis
So I am trying to route a tube between 2 bulkhead fittings.  I select "start at point" and successfully generate the start of the route which I then connect to the target fitting by a line.  How do I end this route so that the tube enters the second fitting  with the specified  straight section?  The same thing happens when I define the tube to be flexible and connect it to the endpoint with a spline.  .
