Loft doesn't follow the loft sketch.
Question asked by Juraj Mihálik on Aug 9, 2017
Latest reply on Aug 10, 2017 by Paul Salvador
Hi guys,
I used the Loft feature to create a thin sheet around a wing. Looking at the generated part, I can see that the face of the Thin Loft doesn't match the loft sketch too well.
I generated the thin loft in One-Direction outwards, but clearly the generated part interfere with the sketch.
This becomes a problem when I assembly this sheet with an inner part created using the same sketch.
Now the two parts are interfering, which is also confirmed by the Interference Detector, So I assume it is not just a visualization problem.
Does anyone have an idea how can I get the loft to follow the sketch more exactly?
I tried increasing the precision in the Document Properties options but nothing changed.
Using the Boundary-Surface feature I get exactly the same contour as for the Loft.
Any ideas?
