Hi everyone,
I'm working with SolidWorks 2016 and a custom Toolbox folder
I have created a few custom toolbox components that use configurations, and have no material assigned. When I create them I set their appearances to a custom appearance, and I apply the same appearance to all configurations of the toolbox component. The problem I'm running into is that SolidWorks applies 'satin finish stainless steel' appearance to my components after I add them to the toolbox. I have even gone into the toolbox and edited the component to change the appearance back to what I had set it to. This works until I go to add it to the assembly again or until I edit an existing version of it in my assembly. At that point it changes back to satin finish stainless steel.
Is there some global toolbox color setting that I can change to prevent this override? Am I missing some step in the process to maintain my colors? Is this a bug?
Thanks in advance for the help,
Quentin
Since you said these are custom files, I assume you started with Toolbox parts and then saved them to a different location with a different name? If yes, I'd suggest removing the Toolbox designation from these files. See the second part of #5 at Frequently Asked Forum Questions.
