SW2013 SP5
I am using a subroutine to determine the center axis of the selected circular pattern. I am running into an issue when trying to get the Axis Property from the circular pattern feature data.
- Get the definition of the pattern (Set myCirPatternData = myFeat.GetDefinition)
- Access the selections for the pattern (If myCirPatternData.AccessSelections(swModel, Nothing) Then)
- Test the Axis type (myCirPatternData.GetAxisType)
Here's where I have the issue. If the pattern axis is either an RefAxis or an Edge it works well. If the axis is a Face the "GetAxisType" returns a 0 (zero) - which is supposed to be an RefAxis. The "GetAxisType" method seems to be the only way to determine what makes up the pattern axis. There has to be another way...
Function CylinderPatternAxisOrigin(myFeat As SldWorks.Feature) As Double() Dim myCirPatternData As SldWorks.CircularPatternFeatureData Dim swEdge As SldWorks.Edge Dim vFace As Variant Dim swFace(1) As SldWorks.Face2 Dim swSurf(1) As SldWorks.Surface Dim swCylSurf As SldWorks.Surface Dim swFlatSurf As SldWorks.Surface Dim swRefAxis As SldWorks.RefAxis Dim swAxisFeature As SldWorks.Feature Dim swTestFeature As SldWorks.Feature Dim swAxisObject As Object Dim vAxisParam As Variant Dim nPt(2) As Double Dim vCylinder As Variant Dim strTest As String ' PatternFeatureArray Set myCirPatternData = myFeat.GetDefinition If myCirPatternData.AccessSelections(swModel, Nothing) Then ' If the axis is a refAxis If myCirPatternData.GetAxisType = 0 Then If myCirPatternData.Axis.GetTypeName() = "RefAxis" Then Set swAxisFeature = myCirPatternData.Axis Set swRefAxis = swAxisFeature.GetSpecificFeature2 vAxisParam = swRefAxis.GetRefAxisParams nPt(0) = vAxisParam(0): nPt(1) = vAxisParam(1): nPt(2) = vAxisParam(2) End If ElseIf myCirPatternData.GetAxisType = 1 Then Set swEdge = myCirPatternData.Axis vFace = swEdge.GetTwoAdjacentFaces2 Set swFace(0) = vFace(0): Set swFace(1) = vFace(1) Set swSurf(0) = swFace(0).GetSurface: Set swSurf(1) = swFace(1).GetSurface If swSurf(0).IsCylinder Then Set swCylSurf = swSurf(0): Set swFlatSurf = swSurf(1) Else Set swCylSurf = swSurf(1): Set swFlatSurf = swSurf(0) End If vCylinder = swCylSurf.CylinderParams nPt(0) = vCylinder(0): nPt(1) = vCylinder(1): nPt(2) = vCylinder(2) End If End If myCirPatternData.ReleaseSelectionAccess CylinderPatternAxisOrigin = nPt End Function
Hi Dave,
Once you obtain the axis feature using 'Set swAxisFeature = myCirPatternData.Axis' set this feature to IEntity object and find out the entity type (whether Face or Axis or Edge) using IEntity.GetType method.
