3 Replies Latest reply on Aug 8, 2017 8:49 AM by Nadav Gover
    Determine if a body is spherical\conical
    Nadav Gover
      Does anyone have an idea how to determine if a body is spherical\conical.
        • Re: Determine if a body is spherical\conical
          Ivana Kolin
          Option Explicit
              Dim swBody As SldWorks.Body2
              Dim swFace As SldWorks.Face2
              Dim swSurface As SldWorks.Surface
              Set swModel = swApp.ActiveDoc
              If swModel.GetType = swDocPART Then
                  Set swPart = swModel
                  Set swBody = swPart.Body
              Else
                  Set swComp = swSelMgr.GetSelectedObjectsComponent2(1)
                  Set swBody = swComp.GetBody
              Set swFace = swBody.GetFirstFace
              While Not swFace Is Nothing
                  Set swSurface = swFace.GetSurface
                  If swSurface.IsSphere Then
                      MsgBox "Sphere"
                      Exit Sub
                  If swSurface.IsCone Then
                      MsgBox "Cone"
                      Exit Sub
                  Set swFace = swFace.GetNextFace
              Wend
            Amen Allah Jlili
            @Nadav_Gover: Better check if the surface is conic or spheric. You'll run into trouble with you have complicated bodies.
