Re: using an assembly variable in a part
John Stoltzfus Aug 7, 2017 12:36 PM (in response to Jim Steinmeyer)Try this one Jim Steinmeyer
https://forum.solidworks.com/message/708932#comment-708932
ps: Keep in mind that it can be easier to search from here
Forum SEARCH RESULTS - Over 160,000 Search Returns - Excel (1/28/2019) Updated - Macros Search
Jim Steinmeyer Aug 7, 2017 2:43 PM (in response to John Stoltzfus)I looked in the spreadsheet first and was using the wrong terms.
I then after your post have reread through the linked posts. I can see where driving things off the master sketch would be of a benefit. With this assembly I am attempting to design an auger system to fit around one of our feeders. Depending on the product used the diameter of the auger may change and so I am attempting to link several parts in several subassemblies to a top level variable that would drive all of the parts. As the parts are on several different planes, and with several different shapes I was hoping to build off global variables but that might be a mistake.
In the following screen shot I have an older auger system that will be replaced laid out roughly how the new one will go. I have the assembly level sketch showing. The first part I was attempting to drive was the square flange shown at the bottom. It will be placed in 4 different places in 3 different subassemblies, two of those just to the upper left of the flange. The inside dimension will be driven by the tube diameter and the best I was able to do using the indicated thread was to select the diameter from the visible sketch and then have that diameter driven by a global variable. I will proceed with that and see how things go. There will actually also be an auger attached to the top that is directed towards the rear but is able to pivot about the top flange.
Thank you
John Stoltzfus Aug 7, 2017 2:59 PM (in response to Jim Steinmeyer)One of the things to keep in mind Jim Steinmeyer - first within any learning curve there will be issues, right... but don't let that deter you from your end goal..
One thing I do want to share using a sketch part to drive an assembly and parts within the assembly, be extremely careful of how many configurations you plug into the main assembly. I had a simple cabinet model here that I thought I might have to trash, I had 6 different configurations and this was a simple design, maybe a few odd parts.. These 6 configurations slowed the drawing down to a crawl, there were approx 45 sheets in the drawing, which should not have been the issue, so what I did is saved the assembly 6 times by doing a Save As Copy and then I opened everyone up and deleted all the configurations except the one that was needed, that helped a little bit, but then I had to go back and delete all the display states but one, what a difference, before it would take a few minutes to go page to page going from configuration to configuration, but when I got to the part tabs, it was quick. This morning I opened the same file and what a difference, no hesitation at all, the drawings were quick...
So watch the amounts of Configuration and Display States....
Jim Steinmeyer Aug 7, 2017 3:05 PM (in response to John Stoltzfus)Will do. Have not been successful with display states to this point so that will not be a problem.
Dennis Dohogne Aug 7, 2017 12:55 PM (in response to Jim Steinmeyer)I'm just speculating here, but would it work if you are editing the part in the context of the assembly where the global variables reside? Would they be visible to your part then?
Jim Steinmeyer Aug 7, 2017 2:19 PM (in response to Dennis Dohogne)Dennis,
No, that is how I thought it would work and that is why I first created the part as a virtual part then attempted to edit it while still in the assembly.
