Hello everyone. I have a convoluted sketch deriving from a picture. Is it possible to quote it automatically to get a fully defined sketch? At most I'd like to specify only height and width.
Thank you for your time.
have you tried the "Fully Define Sketch" feature? it is in the Display/Delete Relations drop down on the sketch tab
Hi @Logan Atkins. After I using the "Fully Define Sketch" feature, if I want to change a single dimension, how can I change automatically all other dimensions so that all relationships between dimensions remain unchanged?
i agree with the mentioned ideas. The only practical ways to do what you want is thru creating a block and scaling that or by scaling the part after you have extruded it. The only way to do it exactly how you want is to add equations to try to link the dimensions together..... but that would certainly not be practical. There is no way that i know of to do it with just relations and 2 dimensions.
