PVPaulus V.05/08/2017
Hello all,
I am an Autodesk Inventor user trying to learn SW and I am trying to recreate a specific 3d sketch that I have done in Inventor. Best way to explain is to show how I've done it:
simple sketch in front plane:
a few concentric circular segments in top plane:
extruded surfaces of the circular segments:
creating a 3d sketch by wrapping the first sketch to the first surface (I need to have the projected line segments 'equal' with equal 'angles' and distance between the points.):
final result - in the same 3d sketch, the first 3d projection is projected 'normal' to the other concentric surfaces:
Is it possible to do this in SolidWorks?
I don't need any solids, the final result will be the 3d sketch, used for a CNC toolpath generation.
