DEDalia Esmeralda De La Torre Meza04/08/2017
Hello, i´m having problems with this assembly. When I last saved it I checked for interferences and there were none, now that I opened it again there are 7. I didn´t modify the components "solera 2 1_2x1_2" that are showing interferences, so I don´t know why there are appearing now. I believe the way i´m building the pieces is in order for them to not intersect and also interference 7 of the "cincho 1" doesn´t make any sense because since it´s a circular pattern the rest of the components "cincho 1" should show an interference as well.
I made an assembly before with a circular pattern of 9 "solera 2 1_2x1_2" only with a different diameter and using the same method of construction. That assembly doesn´t show any interferences.
Does anyone know why this is happening and how I can solve this issue?
Thanks in advance!
