10 Replies Latest reply on Feb 7, 2018 3:17 PM by Robert H.
    Marco to save pdf/dwg in specific directory
    Robert H.
      Hi all
      am looking to get write/modify a macro to save pdf and dwg to a specific directory , expect i can not get the marco to save them in the right folders, i can get them to be saved out on level up  but i can not seam to go down one again to save the PDF/DWG in there respective folders - did try  + "/PDF" + but it doesn't seam to be working
      instead it the macro just adds PDF to the file name , very frustrating, am sure it something simple am missing !!
      Thank you
      Robert
      eg
      Drawing directory
      \430_F12 GLASS SHELVING\CAD FILES\ ( soildworks drawing file)
      PDF / DWG directory
      430_F12 GLASS SHELVING\PDF
      430_F12 GLASS SHELVING\DWG
      Code:
      Dim swApp           As SldWorks.SldWorks
      Dim swModel         As SldWorks.ModelDoc2
      Dim swDraw          As SldWorks.DrawingDoc
      Dim Filepath        As String
      Dim FileName        As String
      Dim Drawingno       As String
      Dim Rev             As String
      Dim Title           As String
      Dim boolstatus As Boolean
      Set swModel = swApp.ActiveDoc
      ' Check to see if a drawing is loaded.
      If (swModel Is Nothing) Or (swModel.GetType <> swDocDRAWING) Then
      swApp.SendMsgToUser ("To be used for drawings only, Open a drawing first and then TRY!")
      ' If no model currently loaded, then exit
      Exit Sub
      Set swDraw = swModel
      Set SWmoddoc = swApp.ActiveDoc
      Filepath = Left(swDraw.GetPathName, InStrRev(swDraw.GetPathName, "\") - 10)
      If Dir(Filepath & "PDF", vbDirectory) = "" Then ' Change Sub folder Name here
      MkDir Filepath + "PDF" ' Change Sub folder Name here
      If Dir(Filepath & "DWG", vbDirectory) = "" Then ' Change Sub folder Name here
      MkDir Filepath + "DWG" ' Change Sub folder Name here
      Drawingno = SWmoddoc.CustomInfo("Drawing No.")
      Rev = SWmoddoc.CustomInfo("version")
      Title = SWmoddoc.CustomInfo("Title")
      swDraw.SaveAs (Filepath + Drawingno + "_#" + Rev + "_" + Title + ".PDF")
      swDraw.SaveAs (Filepath + Drawingno + "_#" + Rev + "_" + Title + ".DWG")
        • Re: Marco to save pdf/dwg in specific directory
          Deepak Gupta
          Replace this line
          with
          Filepath = Left(swDraw.GetPathName, InStrRev(swDraw.GetPathName, "\") )
            Robert H.
            this there not some way to grab the parent folder of the drawing or  grab the path and delete every thing up to the last \
            to reach \430_F12 GLASS SHELVING\
                  Robert H.
                  i could get that to work for me
                  although i have managed to hack something together
                  Dim Rev             As String
                  Dim Compileddir     As String
                  Dim Compileddir2     As String
                  Dim Title           As String
                  Dim strFolder       As String
                  Exit Sub
                  Filepath = Left(swDraw.GetPathName, InStrRev(swDraw.GetPathName, "CAD FILES") - 1)
                  Compileddir = (Filepath + "PDF\" + Drawingno + "_#" + Rev + "_" + Title)
                  Compileddir2 = (Filepath + "DWG\" + Drawingno + "_#" + Rev + "_" + Title)
                  Dim fso As New Scripting.FileSystemObject
                  If fso.FileExists(Compileddir + ".PDF") Then
                  If fso.FileExists(Compileddir2 + ".DWG") Then
                      MsgBox ("File Already Exists.")
                      End
                  swDraw.SaveAs (Compileddir + ".PDF")
                  swDraw.SaveAs (Compileddir2 + ".DWG")
                      Deepak Gupta
                      Glad you got it working.
                          Swapnil Masaye
                          I have the below code to save pdf but the pdf file is saved in same directory and i need a particular path to save the pdf and the pdf file name should be same as that of drawing file which is achieved by below code.But the only thing is bothering me to save in a particulat directory,,
                          Need help
                          Option Explicit
                            Dim swModelDocExt As SldWorks.ModelDocExtension
                            Dim swExportData As SldWorks.ExportPdfData
                            Dim filename As String
                            Dim lErrors As Long
                            Dim lWarnings As Long
                            If swModel Is Nothing Then
                            MsgBox "No current document", vbCritical
                            End
                            If swModel.GetType <> swDocDRAWING Then
                            MsgBox "This Macro only works on Drawings", vbCritical
                            End
                            Set swModelDocExt = swModel.Extension
                            Set swExportData = swApp.GetExportFileData(swExportPdfData)
                            filename = swModel.GetPathName
                            If filename = "" Then
                            MsgBox "Please save the file first and try again", vbCritical
                            End
                            'Save drawing
                            boolstatus = swExportData.SetSheets(swExportData_ExportAllSheets, 1)
                            boolstatus = swModelDocExt.SaveAs(filename, 0, 0, swExportData, lErrors, lWarnings)
                            If boolstatus Then
                            MsgBox "Save as Drawing successful" & vbNewLine & filename
                            Else
                            MsgBox "Save as Drawing failed, Error code:" & lErrors
                            'Save as PDF
                            filename = Strings.Left(filename, Len(filename) - 6) & "PDF"
                            If boolstatus Then
                            MsgBox "Save as PDF successful" & vbNewLine & filename
                            Else
                            MsgBox "Save as PDF failed, Error code:" & lErrors
                            'Save as DXF
                            filename = Strings.Left(filename, Len(filename) - 3) & "DXF"
                            If boolstatus Then
                            MsgBox "Save as DXF successful" & vbNewLine & filename
                            Else
                            MsgBox "Save as DXF failed, Error code:" & lErrors
                          Josh Brady
                          Something else to consider:
                          Don't use "+" to combine (concatenate) two strings.  Use "&", which is the VBA concatenation operator.
