Hi all,
Suppose that I have a wing (a simplified example is below), the wing is presenting a blunt trailing edge.
Now, If I loft the wing surface between two airfoils and using guide curves for the leading and trailing edges, the loft produces two separate surfaces.
The two lines separating the surfaces can be removed by checking 'merge tangent faces". However, Iin order to mesh the wing for an external CFD solver, I need to keep the leading edge line while deleting the trailing edge line.
Thus, I need three distinct surfaces (the upper and lower wing surfaces plus the face representing the blunt trailing edge).
--> wing sketch representing the airfoils and the guide curves
--> zoom on the trailing edge connection
--> resulting trailing edge and leding edge lines
Adil,.. suggest moving your TE curve from the mid to the corner... or, if you what to keep it as is do a DeleteFace Fill of the TE faces to get one face.
