Deepak GuptaDefault DefaultGreg JankowskiSolidWorks Corp
I need someone to help me in finding a macro with what I can export any part or Assembly file in some different format (Available in in Save As menu in Solidworks) like X_T, X_B, STP, STEP, IGS, IGES, prt, STL, DWG, DXF, PDF, 3D PDF etc with a single click.
What I want, that I will run the macro and select the checkbox of what type of format I like to export. Once I will select the required checkbox and click okay, then it will save all requested format in the same directory of main file or any desired directory. I expect an option for Drawing file also where I can export DWG, DXF, PDF from the SLDDRW file with a single click.
Currently I am using Solidworks-2016.
I saw a post like it. But there the requirement was only to export a single format (STEP) “Automatic File Export Macro”. In that post Deepak Gupta gave a great solution. My requirements are same as this post but I want little bit extra. Multiple files with a single click.
With Best Regards
Sobuj
Deepak GuptaDefault DefaultGreg JankowskiSylvain Trudel SolidWorks CorpSolidWorks API Support
Motin,
Have you tried DocExport macro from Lenny
Check this
This will help you to get started and modify if necessary
