Dont know why this is so difficult but I'm trying to create a simple "Chain Dimension" so the dimensions are all collinear "in line with each other" This is very easily done in Autocad but I cannot get this to work in Sworks. I've tried the Ordinate dimension but it will not work on my center lines. Any ideas!
Using Sworks 2017 SP-2
Thanks!
Paul
From what I understand from your quest you are referring to dimensions at the drawing level. This is actually accomplished by selecting all the dimensions you want co linear and hovering over them this symbol will appear:
taking your cursor over this icon will give you this:
I have conveniently even hovered over the appropriate button so you can see the tooltip.
If your question was in context of assembly or parts this will probably not solve your problem. If that is the case I'll require further clarification to help.
