PRINT TO PDF
Question asked by Coractive High-Tech on Aug 3, 2017
Latest reply on Aug 7, 2017 by David Matula
I am looking for a macro that prints to pdf files. I don't want to "save as pdf" since the file takes way more space and is a problem when sending multiple drawings by email.
The path of the file is the same where the draft is and I want the revision to be included at the end of the file name ( _RevX) and if there is no revision then No "_Rev" at the end of the file name.
The following only launches the printer as it was lastly used:
Dim swApp As Object
Dim Part As Object
Dim boolstatus As Boolean
Set swApp = _
Application.SldWorks
Set Part = swApp.ActiveDoc
Part.PrintDirect
Part.ViewZoomtofit2
Part.ViewZoomtofit2
I am using Solidworks 2014
Thank You
