Hey lovely people,
Nice to meet you for the first time.
when I was doing surface modeling,
I have encountered some problems about the surfaces quality with hours' struggling.
The command I tried were Loft in surface and Fill Surface.
Lets take a look at the problem.
I use Loft to form this surface between two flat planes. It was not good. We can see surface of the corner slightly sunken...
So I tried ways to fix it. First, I used Face Curves to substract some curves from the formed surface. Then I deleted the surfaces and build a new surface with those Face Curves using the command Surfaces Fill.
I was very happy with the new surface which looked quite perfect and smooth.
However when I turn on the Curvature Check, it looks very scary....
I am very confused now. Is it a good surface or should I rebuild a new one?
the corner edge is still abit sunken in the picture.... how can I fix it?
Could anyone help?
Thank you!
Hi.
First, if you could attach your model it would be easier to find a solution.
Second, as far i know, curvature display is based on image quality. So you can try to maximize quality in document properties.
..and third try to use boundary boss base or boundary surface tools.
