2 Replies Latest reply on Aug 2, 2017 4:09 PM by Juan David Rico Molano
    Get Volume VBA
      Hello everyone.
      I've had some problems trying to get the volume from the model to a variable into vba. I've found a way and it is like this:
      Dim instance As IMassProperty
      Dim value As System.Double
      value = instance.density
      When I run the macro, Dim value As System.Double is highlighted and this error appears:
      Compile error:
      User-defined type not defined
      I think I need to activate some references but I don't know exactly which one.
      Thank you
