We have a custom task set up to export our drawings to .pdfs. We usually have it set to execute on a stand-alone machine, but that machine is currently down. I decided to set the execution method to my machine for the time being, but it stops and spits out this error. We used to run the .pdf tasks on the local machines in the past and it worked fine, but this is the first time in a while we have tried it again. Any help would be greatly appreciated.
The debugger stops on this line below.
If PathIsRelative( errorLogFolder ) = 1 Then
_______________________________________________________________
Dim swApp As Object
Dim swDrawing As SldWorks.DrawingDoc
Dim swAssembly As SldWorks.AssemblyDoc
Dim swExtension As SldWorks.ModelDocExtension
Dim swConfMgr As SldWorks.ConfigurationManager
Dim swPDFExport As SldWorks.ExportPdfData
Dim swDocSpecification As SldWorks.DocumentSpecification
Dim FileSystemObj as Object
Dim errors As Long
Dim warnings As Long
#If VBA7 Then
Private Declare PtrSafe Function SHCreateDirectoryEx Lib "shell32" Alias "SHCreateDirectoryExA" (ByVal hwnd As Long, ByVal pszPath As String, ByVal psa As Any) As Long
Private Declare PtrSafe Function PathIsRelative Lib "shlwapi.dll" Alias "PathIsRelativeA" (ByVal pszPath As String) As Long
#Else
Private Declare Function SHCreateDirectoryEx Lib "shell32" Alias "SHCreateDirectoryExA" (ByVal hwnd As Long, ByVal pszPath As String, ByVal psa As Any) As Long
Private Declare Function PathIsRelative Lib "shlwapi.dll" Alias "PathIsRelativeA" (ByVal pszPath As String) As Long
#End If
Function PathAppend(path, more) As String
If Not Right(path, 1) = "\" Then
path = path & "\"
If Left(more, 1) = "\" Then
more = Mid(more, 2)
PathAppend = path & more
End Function
Sub Log(message)
Dim errorLogFolder As String
Dim errorLogPath As String
' Determine error log output path
errorLogFolder = "[ErrorLogPath]"
' Trim \ from the start
If Left(errorLogFolder, 1) = "\" Then
errorLogFolder = Mid(errorLogFolder, 2)
' Build full root
errorLogPath = PathAppend("<VaultPath>", errorLogFolder)
Else
errorLogPath = errorLogFolder
' Create directory if not exists
SHCreateDirectoryEx ByVal 0&, errorLogPath, ByVal 0&
errorLogPath = PathAppend(errorLogPath, "<TaskInstanceGuid>.log")
' Write error to output file
Open errorLogPath For Append As #1
Print #1, message
Close #1
Sub CreatePath(path)
If SHCreateDirectoryEx(ByVal 0&, path, ByVal 0&) = 0 Then
' Create temp file
Open path & "~$holder" For Append As #1
Close #1
Sub KillHolder(path)
On Error Goto Ignore
If FileSystemObj.FileExists(path & "~$holder") Then
Kill path & "~$holder"
Ignore:
Function GetExtension(docType, fileFormat)
first = InStr(1, fileFormat, "(")
last = InStr(first, fileFormat, ")")
extensions = Mid(fileFormat, first + 1, last - first - 1)
If InStr(1, extensions, ";") > 0 Then
Dim all As Variant
all = Split(extensions, ";")
If UBound(all) >= docType - 1 Then
ext = all(docType - 1)
Else
ext = "*." ' Nothing
Else
ext = extensions
GetExtension = Mid(Trim(ext), 2)
End Function
Sub SetConversionOptions(ext)
' PDF options
If LCase(ext) = ".pdf" Then
swApp.SetUserPreferenceToggle swPDFExportInColor, [PdfInColor]
swApp.SetUserPreferenceToggle swPDFExportEmbedFonts, [PdfEmbedFonts]
swApp.SetUserPreferenceToggle swPDFExportHighQuality, [PdfHighQuality]
swApp.SetUserPreferenceToggle swPDFExportPrintHeaderFooter, [PdfPrintHeaderFooter]
swApp.SetUserPreferenceToggle swPDFExportUseCurrentPrintLineWeights, [PdfUsePrinterLineWeights]
' IGES
ElseIf LCase(ext) = ".igs" Then
swApp.SetUserPreferenceToggle swIGESExportSolidAndSurface, [IgesExportSolidSurface]
swApp.SetUserPreferenceIntegerValue swIGESRepresentation, [IgesRepresentation]
swApp.SetUserPreferenceToggle swIGESExportAsWireframe, [IgesExportWireframe]
swApp.SetUserPreferenceIntegerValue swIGESCurveRepresentation, [IgesCurveRepresentation]
swApp.SetUserPreferenceIntegerValue swIGESSystem, [IgesSystem]
swApp.SetUserPreferenceToggle swIGESExportFreeCurves, [IgesExportFreeCurves]
swApp.SetUserPreferenceToggle swIGESExportSketchEntities, [IgesExportSketchEntities]
swApp.SetUserPreferenceToggle swIGESHighTrimCurveAccuracy, [IgesHighCurveAccuracy]
swApp.SetUserPreferenceToggle swIGESComponentsIntoOneFile, [IgesComponentsIntoOneFile]
swApp.SetUserPreferenceToggle swIGESFlattenAssemHierarchy, [IgesFlattenAssemblyHierarchy]
' ACIS
ElseIf LCase(ext) = ".sat" Then
swApp.SetUserPreferenceIntegerValue swAcisOutputGeometryPreference, [AcisGeometry]
swApp.SetUserPreferenceIntegerValue swOutputVersion, [AcisVersion]
swApp.SetUserPreferenceIntegerValue swAcisOutputUnits, [AcisOutputAsUnit]
' STEP
ElseIf LCase(ext) = ".step" Then
swApp.SetUserPreferenceIntegerValue swAcisOutputGeometryPreference, [StepGeometry]
swApp.SetUserPreferenceIntegerValue swStepAP, [StepVersion]
' Parasolid
ElseIf LCase(ext) = ".x_t" Or LCase(ext) = ".x_b" Then
swApp.SetUserPreferenceIntegerValue swParasolidOutputVersion, [ParasolidVersion]
swApp.SetUserPreferenceToggle swXTAssemSaveFormat, [ParasolidFlattenHierarchy]
' VRML
ElseIf LCase(ext) = ".wrl" Then
swApp.SetUserPreferenceIntegerValue swExportVrmlUnits, [VrmlOutputAsUnit]
swApp.SetUserPreferenceToggle swExportVrmlAllComponentsInSingleFile, [VrmlSaveAssemblyAsOneFile]
' STL
ElseIf LCase(ext) = ".stl" Then
swApp.SetUserPreferenceToggle swSTLBinaryFormat, [StlOutputAs]
swApp.SetUserPreferenceIntegerValue swExportStlUnits, [StlOutputAsUnit]
swApp.SetUserPreferenceIntegerValue swSTLQuality, [StlQuality]
swApp.SetUserPreferenceToggle swSTLDontTranslateToPositive, [StlDontTranslatePositive]
swApp.SetUserPreferenceToggle swSTLComponentsIntoOneFile, [StlComponentsIntoOneFile]
swApp.SetUserPreferenceToggle swSTLCheckForInterference, [StlCheckForInterferences]
' TIF or PSD
ElseIf LCase(ext) = ".tif" Or LCase(ext) = ".psd" Then
swApp.SetUserPreferenceIntegerValue swTiffImageType, [TifImageType]
swApp.SetUserPreferenceIntegerValue swTiffCompressionScheme, [TifCompressionScheme]
' eDrawings
ElseIf LCase(ext) = ".eprt" Or LCase(ext) = ".easm" Or LCase(ext) = ".edrw" Then
swApp.SetUserPreferenceToggle swEDrawingsOkayToMeasure, [EdrwOkayToMeasure]
swApp.SetUserPreferenceToggle swEDrawingsExportSTLOkay, [EdrwAllowExportOfSTL]
swApp.SetUserPreferenceToggle swEDrawingsSaveShadedDataInDrawings, [EdrwSaveShadedData]
swApp.SetUserPreferenceToggle swEDrawingsSaveBOM, [EdrwSaveBOM]
swApp.SetUserPreferenceToggle swEDrawingsSaveAnimationOkay, [EdrwSaveMotionStudies]
swApp.SetUserPreferenceToggle swEDrawingsSaveAnimationToAllConfigs, [EdrwSaveMotionStudiesToAllConfs]
swApp.SetUserPreferenceToggle swEDrawingsSaveAnimationRecalculate, [EdrwRecalcMotionStudies]
Function GetFullFileName(convFileName, conf, i, itemCount)
' Configuration name may include backslash. Remove it since otherwise saving will
' fail due a missing directory
conf = Replace(conf, "\", "")
conf = Replace(conf, "/", "")
finalFileName = Replace(convFileName, "<Configuration>", conf)
' If no configuration
If finalFileName = convFileName And itemCount > 0 Then
finalFileName = Left(convFileName, InStrRev(convFileName, ".") - 1) & "_" & i & Mid(convFileName, InStrRev(convFileName, "."))
' Remove illegal characters from filename
finalFileName = Replace(finalFileName, "<", "")
finalFileName = Replace(finalFileName, ">", "")
finalFileName = Left(finalFileName, 2) + Replace(finalFileName, ":", "", 3) ' Don't start from begin since drive has :
finalFileName = Replace(finalFileName, "*", "")
finalFileName = Replace(finalFileName, "?", "")
finalFileName = Replace(finalFileName, """", "")
finalFileName = Replace(finalFileName, "|", "")
GetFullFileName = finalFileName
End Function
Sub Convert(docFileName)
' Constants for some SolidWorks error/warning returns that may be encountered during a convert operation.
Const swerr_InvalidFileExtension = 256 ' the file extension differs from the SW document type.
Const swerr_SaveAsNotSupported = 4096 ' the options selected for this convert aren't supported, output may be incomplete.
Const swwarn_MissingOLEObjects = 512 ' the document contains OLE objects and must be opened and converted in SolidWorks.
' Determine type of SolidWorks file based on file extension
If LCase(Right(docFileName, 7)) = ".sldprt" Or LCase(Right(docFileName, 4)) = ".prt" Then
docType = swDocPART
ElseIf LCase(Right(docFileName, 7)) = ".sldasm" Or LCase(Right(docFileName, 4)) = ".asm" Then
docType = swDocASSEMBLY
ElseIf LCase(Right(docFileName, 7)) = ".slddrw" Or LCase(Right(docFileName, 4)) = ".drw" Then
docType = swDocDRAWING
Else
docType = swDocNONE
If bIsSupportedExtension(Mid(docFileName, InStrRev(docFileName, ".") + 1)) = False Then
Log "The file extension '" & Mid(docFileName, InStrRev(docFileName, ".") + 1) & "' is not supported."
Exit Sub
' Open document
If docType = swDocNONE Then
Set swModel = swApp.LoadFile4(docFileName, "", Nothing, errors)
docType = swModel.GetType
Else
Set swDocSpecification = swApp.GetOpenDocSpec(docFileName)
swDocSpecification.DocumentType = docType
swDocSpecification.ReadOnly = True
swDocSpecification.Silent = True
swDocSpecification.ConfigurationName = ""
swDocSpecification.DisplayState = ""
Set swModel = swApp.OpenDoc7(swDocSpecification)
errors = swDocSpecification.Error
' Set swModel = swApp.OpenDoc6(docFileName, docType, swOpenDocOptions_Silent Or swOpenDocOptions_ReadOnly, "", errors, warnings)
If errors = swFutureVersion Then
Log "Document '" & docFileName & "' is future version."
Exit Sub
' Load failed?
If swModel Is Nothing Then
Log "Method call ModelDoc2::OpenDoc7 for document '" & docFileName & "' failed. Error code " & errors & " returned."
Exit Sub
If Val(Left(swApp.RevisionNumber, 2)) >= 18 Then
swApp.Frame.KeepInVisible = True
swApp.ActivateDoc2 docFileName, True, errors
modelPath = swModel.GetPathName()
If modelPath = "" Then
modelPath = docFileName
modelFileName = Mid(modelPath, InStrRev(modelPath, "\") + 1)
modelFileName = Left(modelFileName, InStrRev(modelFileName, ".") - 1)
modelExtension = Mid(modelPath, InStrRev(modelPath, ".") + 1)
' Build destination filenames
convFileName = "[OutputPath]"
Dim convFileName2 As String
convFileName2 = "[OutputPath2]"
Dim convFilePath2 As String
Dim convFileNameTemp2 As String
Dim bSecondOutput As Boolean
bSecondOutput = False
If (Len(convFileName2) > 0) Then
bSecondOutput = True
ext = GetExtension(docType, "[FileFormat]")
convFileName = Replace(convFileName, "<Filename>", modelFileName)
convFileName = Replace(convFileName, "<Extension>", modelExtension)
convFilePath = Left(convFileName, InStrRev(convFileName, "\"))
CreatePath convFilePath
convFileName = convFileName & ext
If bSecondOutput = True Then
convFileName2 = Replace(convFileName2, "<Filename>", modelFileName)
convFileName2 = Replace(convFileName2, "<Extension>", modelExtension)
convFilePath2 = Left(convFileName2, InStrRev(convFileName2, "\"))
CreatePath convFilePath2
convFileName2 = convFileName2 & ext
' Set conversion options
SetConversionOptions ext
Set swExtension = swModel.Extension
If docType = swDocDRAWING Then
Dim vSheetNames As Variant
Set swDrawing = swModel
' All sheets?
If ([OutputSheets] And 2) = 2 Then
vSheetNames = swDrawing.GetSheetNames
' Last active sheet?
ElseIf ([OutputSheets] And 4) = 4 Then
ReDim vSheetNames(0 to 0) As Variant
vSheetNames(0) = swDrawing.GetCurrentSheet.GetName()
' Named sheet
ElseIf ([OutputSheets] And 8) = 8 Then
Dim vSheetNamesTemp As Variant
vSheetNamesTemp = swDrawing.GetSheetNames
removed = 0
For i = 0 To UBound(vSheetNamesTemp)
vSheetNamesTemp(i-removed) = vSheetNamesTemp(i)
sheetName = vSheetNamesTemp(i)
If Not sheetName Like "[NamedSheet]" Then
removed = removed + 1
EndIf
Next i
If (UBound(vSheetNamesTemp) - removed) >= 0 Then
ReDim Preserve vSheetNamesTemp(0 To (UBound(vSheetNamesTemp) - removed))
vSheetNames = vSheetNamesTemp
If Not IsEmpty(vSheetNames) Then
' Save sheets one per file
If ([FileSheets] And 4) = 4 Then
For i = 0 To UBound(vSheetNames)
Dim varSheetName As Variant
swDrawing.ActivateSheet vSheetNames(i)
convFileNameTemp = GetFullFileName(convFileName, vSheetNames(i), i, UBound(vSheetNames))
Set swPDFExport = swApp.GetExportFileData(1)
varSheetName = vSheetNames(i)
swPDFExport.SetSheets swExportData_ExportSpecifiedSheets, varSheetName
ElseIf LCase(ext) = ".edrw" Then
swApp.SetUserPreferenceIntegerValue swEdrawingsSaveAsSelectionOption, swEdrawingSaveActive
' Convert the document
Success = swExtension.SaveAs(convFileNameTemp, swSaveAsCurrentVersion, swSaveAsOptions_Silent, swPDFExport, errors, warnings)
' Save failed?
If Success = False Then
If errors = swerr_InvalidFileExtension Then
Log "The file '" & docFileName & "' and sheet '" & vSheetNames(i) & "' can't be converted to the file extension '" & ext & "'."
Else
Log "Method call ModelDocExtension::SaveAs for document '" & convFileNameTemp & "' and sheet '" & vSheetNames(i) & "' failed. Error code " & errors & " returned."
If (((errors And swerr_SaveAsNotSupported) <> 0) And ((warnings And swwarn_MissingOLEObjects) <> 0)) Then
Log "This document contains OLE objects. Such objects can't be converted outside of SolidWorks. Please open the document and perform the conversion from SolidWorks."
End if
convFileNameTemp2 = GetFullFileName(convFileName2, vSheetNames(i), i, UBound(vSheetNames))
Success = swExtension.SaveAs(convFileNameTemp2, swSaveAsCurrentVersion, swSaveAsOptions_Silent, swPDFExport, errors, warnings)
' Save failed?
Else
Log "Method call ModelDocExtension::SaveAs for document '" & convFileNameTemp2 & "' and sheet '" & vSheetNames(i) & "' failed. Error code " & errors & " returned."
End if
Next i
' Save PDF sheets to one file
ElseIf ([FileSheets] And 2) = 2 Then
Set swPDFExport = swApp.GetExportFileData(swExportPdfData)
swPDFExport.SetSheets swExportData_ExportSpecifiedSheets, vSheetNames
If ([OutputSheets] And 2) = 2 Then ' All sheets?
swApp.SetUserPreferenceIntegerValue swEdrawingsSaveAsSelectionOption, swEdrawingSaveAll
ElseIf ([OutputSheets] And 4) = 4 Then ' Last active sheet?
ElseIf ([OutputSheets] And 8) = 8 Then ' Named sheet
swApp.SetUserPreferenceIntegerValue swEdrawingsSaveAsSelectionOption, swEdrawingSaveSelected
selectedSheets = Join(vSheetNames, vbLf)
swApp.SetUserPreferenceStringListValue swEmodelSelectionList, Trim(selectedSheets)
convFileNameTemp = GetFullFileName(convFileName, "All", 0, 0)
' Save failed?
Log "Method call ModelDocExtension::SaveAs for document '" & convFileNameTemp & "' failed. Error code " & errors & " returned."
convFileNameTemp2 = GetFullFileName(convFileName2, "All", 0, 0)
' Save failed?
Log "Method call ModelDocExtension::SaveAs for document '" & convFileNameTemp2 & "' failed. Error code " & errors & " returned."
Else
Log "Document '" & docFileName & "' didn't contain any sheets named '[NamedSheet]'."
Else
Dim vConfNames As Variant
Set swConfMgr = swModel.ConfigurationManager
' All configurations?
If ([OutputConfs] And 2) = 2 Then
vConfNames = swModel.GetConfigurationNames
' Last active conf?
ElseIf ([OutputConfs] And 4) = 4 Then
ReDim vConfNames(0 to 0) As Variant
vConfNames(0) = swConfMgr.ActiveConfiguration.Name
' Named confs
ElseIf ([OutputConfs] And 8) = 8 Then
Dim vConfNamesTemp As Variant
vConfNamesTemp = swModel.GetConfigurationNames
removed = 0
For i = 0 To UBound(vConfNamesTemp)
vConfNamesTemp(i-removed) = vConfNamesTemp(i)
confName = vConfNamesTemp(i)
If Not confName Like "[NamedConf]" Then
EndIf
Next i
If (UBound(vConfNamesTemp) - removed) >= 0 Then
ReDim Preserve vConfNamesTemp(0 To (UBound(vConfNamesTemp) - removed))
vConfNames = vConfNamesTemp
If Not IsEmpty(vConfNames) Then
If ([FileConfs] And 4) = 4 Then
' Save configurations
For i = 0 To UBound(vConfNames)
swModel.ShowConfiguration vConfNames(i)
convFileNameTemp = GetFullFileName(convFileName, vConfNames(i), i, UBound(vConfNames))
Success = swExtension.SaveAs(convFileNameTemp, swSaveAsCurrentVersion, swSaveAsOptions_Silent, Nothing, errors, warnings)
' Save failed?
Log "The file '" & docFileName & "' and configuration '" & vConfNames(i) & "' can't be converted to the file extension '" & ext & "'."
Else
Log "Method call ModelDocExtension::SaveAs for document '" & convFileNameTemp & "' and configuration '" & vConfNames(i) & "' failed. Error code " & errors & " returned."
convFileNameTemp2 = GetFullFileName(convFileName2, vConfNames(i), i, UBound(vConfNames))
Success = swExtension.SaveAs(convFileNameTemp2, swSaveAsCurrentVersion, swSaveAsOptions_Silent, Nothing, errors, warnings)
' Save failed?
Else
Log "Method call ModelDocExtension::SaveAs for document '" & convFileNameTemp2 & "' and configuration '" & vConfNames(i) & "' failed. Error code " & errors & " returned."
Log "warnings1 = " & warnings
Next i
ElseIf ([FileConfs] And 2) = 2 Then
If LCase(ext) = ".eprt" Or LCase(ext) = ".easm" Then
If ([OutputConfs] And 2) = 2 Then ' All confs?
ElseIf ([OutputConfs] And 4) = 4 Then ' Last active conf?
ElseIf ([OutputConfs] And 8) = 8 Then ' Named confs
selectedConfs = Join(vConfNames, vbLf)
swApp.SetUserPreferenceStringListValue swEmodelSelectionList, Trim(selectedConfs)
' Save failed?
' Save failed?
Else
Log "Document '" & docFileName & "' didn't contain any configurations named '[NamedConf]'."
KillHolder convFilePath
KillHolder convFilePath2
' Process virtual components
If docType = swDocASSEMBLY Then
Dim vComponents As Variant
Set swAssembly = swModel
vComponents = swAssembly.GetComponents(True)
If Not IsEmpty(vComponents) Then
For i = 0 To UBound(vComponents)
Dim swComponent As SldWorks.Component2
Set swComponent = vComponents(i)
If swComponent.IsVirtual Then
Convert swComponent.GetPathName()
Next i
' Close document
swApp.QuitDoc swModel.GetTitle
Function bIsSupportedExtension(oExtension) As Boolean
oExtension = LCase( oExtension )
If oExtension = "prt" Then
bIsSupportedExtension = True
ElseIf oExtension = "asm" Then
ElseIf oExtension = "drw" Then
ElseIf oExtension = "dxf" Then
ElseIf oExtension = "dwg" Then
ElseIf oExtension = "psd" Then
ElseIf oExtension = "ai" Then
ElseIf oExtension = "lfp" Then
ElseIf oExtension = "sldlfp" Then
ElseIf oExtension = "prtdot" Then
ElseIf oExtension = "asmdot" Then
ElseIf oExtension = "drwdot" Then
ElseIf oExtension = "x_t" Then
ElseIf oExtension = "x_b" Then
ElseIf oExtension = "xmt_txt" Then
ElseIf oExtension = "xmt_bin" Then
ElseIf oExtension = "igs" Then
ElseIf oExtension = "iges" Then
ElseIf oExtension = "step" Then
ElseIf oExtension = "stp" Then
ElseIf oExtension = "sat" Then
ElseIf oExtension = "vda" Then
ElseIf oExtension = "wrl" Then
ElseIf oExtension = "stl" Then
ElseIf oExtension = "cgr" Then
ElseIf oExtension = "xpr" Then
ElseIf oExtension = "xas" Then
ElseIf oExtension = "ipt" Then
ElseIf oExtension = "iam" Then
ElseIf oExtension = "par" Then
ElseIf oExtension = "psm" Then
ElseIf oExtension = "ckd" Then
ElseIf oExtension = "emn" Then
ElseIf oExtension = "brd" Then
ElseIf oExtension = "bdf" Then
ElseIf oExtension = "idb" Then
ElseIf oExtension = "3dm" Then
Else
bIsSupportedExtension = False
End Function
On Error GoTo Fail:
Set FileSystemObj = CreateObject("Scripting.FileSystemObject")
docFileName = "<Filepath>"
' Get SW interface object
swApp.Visible = True
Convert docFileName
Exit Sub
Fail:
Log "Error while converting file '" & docFileName & "': " & vbCrLf & _
"An unexpected error occurred while executing the generated script. Script syntax error?" & vbCrLf & _
"Error number: " & Err.Number & vbCrLf & _
"Error description: '" & Err.Description & "'" & vbCrLf
It's a microsoft function call and it seems corrupted or missing. What OS do you have now on that computer? you might need to download or run the repair dll tools
