Is there a means to find a sketch in a complex part. I do not want to look under every feature in the feature tree. The sketch number is identified because a later sketch uses it for a sketch relation.
Patrick Greller Anytime you have an important sketch like that name it and then filter it like Philip Downing mentioned..
Hi Patrick,
You could always use the filter selection in the FeatureManager Design Tree to look for the sketch you are after:
Does this answer your question?
Kind regards,
Phil.
