I tried to move my sketch to be on the origin, but the extrude didn't move with the sketch.
In the file you attached...the extrudes match the sketch. The problem you are claiming, does not exist in the file.
How are you "moving" the sketch?
I picked a point on the sketch and made in coincident with the origin. I did this because I wanted to fully define the sketch. I just dimensioned the distance to the origin instead of making it coincident.
I think I finally understand. You've brought in a sketch picture and traced it with sketched lines, and you want to move it to the origin. I moved all the lines to get them as close to the picture outline as I could, then box-selected all of them and choose the Sketch Tool "Move Entities". That allowed me to move all the entities together without the shape becoming distorted. I grabbed the center point of the radius and moved it to snap to the origin. I then box-selected all the lines again and applied the Fix relation to define the sketch.
You'll then need to edit the sketch for Boss-Extrude2 to get it in the right place.
Your current sketch in the part you attached...
The highlighted dimensions control the location of the sketch, relative to the origin...
Edit those dimensions to put the sketch where you want it to be in relation to the origin...
Once you have it where you want it, accept the result by exiting the sketch...
(Do Not "Cancel" the sketch...clicking on the X will Cancel the sketch and discard any changes.)
Then you will need to edit the sketch for Boss-Extrude2, since you did not properly constrain it.
(If you had properly constrained it...it would have followed Boss-Extrude1.)
And then everything will be moved...
...except for those "sketch pictures" you stuck in the sketches, because they are just pictures that you put in the sketches for some reason.
