We have an assembly that is going to need a heat shield.
Is it possible to say, 'create a surface that is at least 10mm off from assembly', and then trim and thicken to suit?
I'm trying to add a file for you to show me what you mean, but I cannot seem to see anywhere I can add files, only pictures. There's no link for advanced editor. Has something changed? I'll attached a photo, and hopefully you can still help.
Basically, I cannot seem to get the system to allow me to cavity an assembly. I almost want to create a curvature of the outer edge.
Imagine you were going to create a cover, 10mm from the top edge i.e. this is surface mount, and it to curve to suit (not be ridgid). This will be a vacuum formed item.
Check #18 of Forum Posting on how to attach files while replying to a post.
Other option would be to save assembly as part with exterior faces only option.
It appears that trying to reply from your inbox won't allow file attachment. Must be some malware protective process.
Anyway, I can now attache, butI have moved on from this. I spoke with our support team, not really a goer for offset surfaces. Too many bodies.
However, I created a 3D sketch from assy, then extruded a surface from that. However, I cannot create a flat pattern. I cannot see why not.
Any ideas?
See the video that I posted here:
Trying to enclose a part with an external boundary layer
Edit: You should be able to do the same thing, except with your final part, add it to the assembly instead of adding it to the original part.
Yes, there are a lot of tools that don't like each other on here.
I remember trying to model a 150x50 channel up the edge of a curved staircase a few years back. It took me 2 days to find a way to stop it from twisting, whilst avoiding splines as a guide rail.
Who does the Beta testing for this software? I must be trying to use the software outside if it's remit. Otherwise, why is so difficult to do such simple things?
Yes, Solidworks is not a fan of splines.
I had to convert the spline so I could create a surface. However, if I thicken a surface it should automatically be flatten..able...
Now I have to create another sketch completely.
Step one: draw circle on wall.
Step two: bang head repeatedly until this makes sense.
If step two fails; Step 3: assume the fetal position and suck thumb..
Steve,
This was one of the methods discussed with the support team. However, there are about 1000 odd surfaces. It may take an eternity to get that one down this way.
The cover ends up looking a bit like this. Although the offset part is proving to be a bit more difficult than originally thought
I had to create a 3D sketch within the assembly. Create curved points, extrude the surface, and thicken. Although this will be impossible to flatten
Yes there can be several ways:
1. Start a new part in context of assembly OR insert a new blank part. Now offset from the external faces with required distance and then thicken to suit.
2. Start a new part in context of assembly and draw a block big enough to cover the assembly OR insert a new part having a block feature. Now use cavity feature (this is available when you edit a part in assembly) and subtract the assembly components to get the shell. Add/remove thickness as needed.
You would have to pick the methods based on the complexity of the assy.
