I frequently turn on&off the setting to Enable Snapping in the Tools/Sketch Tools menu. Similarly I frequently use the setting Automatic Relations. There is an icon for Automatic Relations, and a 'status indicator' on the toolbar menu indicates whether it's set on or off. I'd like to have a similar toolbar menu icon for the Enable Snapping on/off status. I have assigned the letter 'E' to that command, but in order to enable or disable it, I have to either walk my way into settings, or test its status, and then turn it on or off with my E. Not ideal. Can an icon be created on the next SP? Thanks.
Did you know that you can just hold down Ctrl while placing sketch entities? That will disable snapping. They're enabled again as soon as you release it.
