I was wondering if there is a way to tell what is under defined in a sketch other than the obvious of it being blue. The reason I ask is because I have a sketch currently that appears to be fully defined but Solid Works says otherwise.
OK, a couple of things:
1) There is a possibility of an "unintentional" micro line: Tiny unintentional sketch lines
If this is the case, then using Repair sketch will locate it for you.
2) If there is text in the sketch, then Sketch Text is hard to fully define (even though it IS fully defined, Solidworks says that it isn't).
Start grabbing endpoints and dragging them around. If defined, they won't move.
