KSKevin Shields28/07/2017
I'm trying to export a .sldprt as a .dxf. I do this with the 'save as' command, select filetype as .dxf, then go through the DXF/DWG export wizard. This process worked perfectly for me until today. The issue I'm having is that visible sketches don't appear in the final .dxf. I'm not sure what settings changed in solidworks that could have changed this behavior.
Does anyone know what could be causing this behavior? I've attached a photo of the sketch not appearing.
