1 Reply Latest reply on Aug 25, 2017 7:36 AM by Cad Admin
    VBA - Limit Number of Stacked Balloons
    Cad Admin
      Side question from another post.  I have a macro that adds a stacked balloon to an existing balloon & formats it as you see below.  Is there a way to limit it to just the run on a single balloon and added description.  I don't want to be able to run it again and add to the stack again, and again, and again.
      • I need to limit the macro to only run on “single balloons. So basically checking the balloon stack count is < 1, anything 1 or higher it skips.  I tried swNote.GetBalloonStack.Count, with inconsistent results and object not defined error after a few successful checks
      Option Explicit
          Dim swApp                       As SldWorks.SldWorks
          Dim swModel                     As ModelDoc2
          Dim swDraw                      As DrawingDoc
          Dim swView                      As View
          Dim swNote                      As Note
          Dim swAnn                       As Annotation
          Dim swSelMgr                    As SldWorks.SelectionMgr
          Dim modelDocExt                 As SldWorks.ModelDocExtension
          Dim vAttEntArr                  As Variant
          Dim vAttEntTypeArr              As Variant
          Dim swEnt                       As SldWorks.Entity
          Dim swComp                      As SldWorks.Component
          Dim swCompModel                 As SldWorks.ModelDoc
          Dim i                           As Long
          Dim bRet                        As Boolean
          Dim ret                         As Long
          Dim boolstatus                  As Boolean
          Set swModel = swApp.ActiveDoc
          Set swDraw = swModel
          Set swView = swDraw.GetFirstView
          Set swView = swView.GetNextView
          While Not swView Is Nothing
              Debug.Print "-------------------"
              Debug.Print swView.Name
              Set swNote = swView.GetFirstNote
              While Not swNote Is Nothing
              Set swAnn = swNote.GetAnnotation
                  Debug.Assert swNote.IsBomBalloon
                  vAttEntArr = swAnn.GetAttachedEntities2: If IsEmpty(vAttEntArr) Then Exit Sub
                  vAttEntTypeArr = swAnn.GetAttachedEntityTypes
                  Debug.Assert UBound(vAttEntArr) = UBound(vAttEntTypeArr)
                  For i = 0 To UBound(vAttEntArr)
                      If swSelNOTHING <> vAttEntTypeArr(i) Then
                          Set swEnt = vAttEntArr(i)
                          Set swComp = swEnt.GetComponent
                          Set swCompModel = swComp.GetModelDoc
                          Set modelDocExt = swCompModel.Extension
                          ret = modelDocExt.ToolboxPartType
                          If ret <> 0 And swNote.GetBalloonStyle <> 10 Then
                              Debug.Print "File = " & swModel.GetPathName
                              Debug.Print "  Name                 = " & swAnn.GetName
                              Debug.Print "    Is stacked         = " & swNote.IsStackedBalloon
                              Debug.Print "    Is stacked master  = " & swNote.IsStackedBalloonMaster
                              Debug.Print "    AttEntType         = " & vAttEntTypeArr(i)
                              Debug.Print "    Balloon style      = " & swNote.GetBalloonStyle
                              Debug.Print "    Toolbox Part       = " & ret
                              Dim myBalloonStack      As Object
                              Dim swNote2             As Object
                              If Not swNote Is Nothing Then
                                      Dim AttachPosition As Variant
                                      Dim StackCount As Long
                                      Dim StackArray As Variant
                                      AttachPosition = swNote.GetAttachPos 'Get the attachment point of the current note
                                      swAnn.Select3 True, Nothing 'Select the current note
                                      swApp.RunCommand swCommands_Resume_Stacking_Balloons, "" 'RMB -> Add to Stack
                                      If vAttEntTypeArr(i) = swSelFACES Then    'Determine if the note is attached to a face or to an edge
                                          swModel.Extension.SelectByID2 "", "FACE", AttachPosition(0), AttachPosition(1), AttachPosition(2), False, 0, Nothing, Empty
                                      ElseIf vAttEntTypeArr(i) = swSelEDGES Then
                                          swModel.Extension.SelectByID2 "", "EDGE", AttachPosition(0), AttachPosition(1), AttachPosition(2), False, 0, Nothing, Empty
                                      swApp.RunCommand swCommands_PmOK, "" 'Click okay in the Propertymanager
                                      Set myBalloonStack = swNote.GetBalloonStack 'Get the balloonstack, to change the note that has just been added
                                      If Not myBalloonStack Is Nothing Then
                                          StackCount = myBalloonStack.Count
                                          StackArray = myBalloonStack.Stack
                                          Set swNote2 = StackArray(StackCount - 1)
                                          swNote2.SetBomBalloonText 1, "$PRPMODEL:""Description""", 1, ""
                                          swNote2.SetBalloon swBalloonStyle_e.swBS_Underline, swBalloonFit_e.swBF_Tightest
                  Next i
              Set swNote = swNote.GetNext
              Wend
          Wend
