Hi
I need to add area column in BOM table which shoes me area of each part separately in square inch .
is it possible.
Kindly suggest.
Raj
Hi
is it possible.
Kindly suggest.
Raj
HI Raj, columns available to show in the BOM are based on custom properties of the parts shown in the table. So you need to go through each part model and add the property under File > Properties > Custom as pictured below.
When you save and return to the drawing, you should be able to add this extra column to the BOM as it will be detected as a property to show.
Each part needs to have this property added to give you a complete list
Adam
