Hi there,
I am wanting to export a DWG/DWF file to open in Illustrator, and the splines created are jaggy and are not creating smooth curves. Is there something I am doing wrong with export?
Thanks.
Hi there,
Thanks.
Thanks John. I got to it there. However changing the options there only effects if I export from 'Drawings' only and not in my SLDPRT. Is there a way if doing it without needing create a new drawing as its a bit tedious.
Thanks.
Alex, oddly enough ... If you click the "Enable Merging" it will allow you to select the High quality DXF export option. Though, truth be told I really don't know if that will help your resolution in any way. We do a lot of DXF exports but are not typically concerned with the resolution aspects.
Good luck with it ...
The best results come from exporting from a Drawing in my experience. You could also get a free PDF printer utility so you could save a PDF, which might give you better results than a DXF/DWG. The built in SW PDF export will rasterize all the curves so you will get an image instead of vector curves/paths.
Have you tried adjusting the settings? Set "High quality DWG export", see below.
