2 Replies Latest reply on Jul 23, 2017 5:26 PM by Richard Martin
    not solid .ai file
    Mark Hanchett
      Not every graphic file creates problem for me. But next one .ai file created. Yesterday I opened Adobe Illustrator and .ai file viewed only a half of data, the rest was lost.
        • Re: not solid .ai file
          Bjorn Hulman
          From drawing? save as pdf.
            Richard Martin
            There is one more trick is to use keyword phrase like this illustrator repair for search machine or apply manual guide below
            Check for a damaged pattern, gradient, or custom color
            To determine if the problem is caused by a damaged pattern, gradient, or custom color:
               1. Choose Edit > Select All and change the fill and stroke to process black.
               2. Perform task 4 again to determine whether the problem occurs in a new file that does not contain the patterns, gradients, or spot colors. If the problem does not recur, re-create the pattern, gradient, or spot color in the original file.
