select " PLANARSURFACE" and " 3DPROFILEFEATURE" in the tree manager
Question asked by Korbi Anis on Jul 20, 2017
Hi friends ; I used this macro to traverse the tree manager and select " planarsurface " or " 3Dprofilefeature" if exist !
the problem that when I run the macro it select " palanarsurface" onlu not twice !! whats the problem ? .thanks
this is my macro :
Sub deletesurfaceSKETCH()
Dim swApp                       As SldWorks.SldWorks
    Dim swModel                     As SldWorks.ModelDoc2
    Dim swConfMgr                   As SldWorks.ConfigurationManager
    Dim swConf                      As SldWorks.Configuration
    Dim swRootComp                  As SldWorks.Component2
    Dim StartTime                   As Double
    Dim FinishTime                  As Double
    Dim TotalTime                   As Double
     Dim sPadStr                     As String
         Dim swSubFeat                   As SldWorks.Feature
    Dim swSubSubFeat                As SldWorks.Feature
    Dim swSubSubSubFeat             As SldWorks.Feature
    Set swModel = swApp.ActiveDoc
    Set swConfMgr = swModel.ConfigurationManager
    Set swConf = swConfMgr.ActiveConfiguration
    Set swRootComp = swConf.GetRootComponent3(True)
    StartTime = Timer ' Start time
    Debug.Print "File = " & swModel.GetPathName
    TraverseModelFeatures swModel, 1
    If swModel.GetType = SwConst.swDocASSEMBLY Then
        TraverseComponent swRootComp, 1
    FinishTime = Timer ' End time
    TotalTime = FinishTime - StartTime ' Elapsed time
    Debug.Print ("Time = " & TotalTime & " sec")
    swModel.EditDelete
    swModel.ClearSelection2 True
    '================================================= SELECT SKETCH3D ==============================================================
Sub TraverseFeatureFeatures(swFeat As SldWorks.Feature, nLevel As Long)
    Dim i                           As Long
    For i = 0 To nLevel
        sPadStr = sPadStr + "  "
    Next i
    While Not swFeat Is Nothing
        Debug.Print sPadStr + swFeat.name + " [" + swFeat.GetTypeName + "]"
        Set swSubFeat = swFeat.GetFirstSubFeature
           If swFeat.GetTypeName = "PlanarSurface" Then
swFeat.Select True
        While Not swSubFeat Is Nothing
            Debug.Print sPadStr + "  " + swSubFeat.name + " [" + swSubFeat.GetTypeName + "]"
            Set swSubSubFeat = swSubFeat.GetFirstSubFeature
             If swSubSubFeat.GetTypeName = "3DProfileFeature" Then
swSubFeat.Select True
     While Not swSubSubFeat Is Nothing
                Debug.Print sPadStr + "    " + swSubSubFeat.name + " [" + swSubSubFeat.GetTypeName + "]"
                Set swSubSubSubFeat = swSubSubFeat.GetFirstSubFeature
                While Not swSubSubSubFeat Is Nothing
                    Debug.Print sPadStr + "      " + swSubSubSubFeat.name + " [" + swSubSubSubFeat.GetTypeName + "]"
                    Set swSubSubSubFeat = swSubSubSubFeat.GetNextSubFeature()
                Wend
                Set swSubSubFeat = swSubSubFeat.GetNextSubFeature()
            Wend
            Set swSubFeat = swSubFeat.GetNextSubFeature()
        Wend
        Set swFeat = swFeat.GetNextFeature
  Wend
Sub TraverseComponentFeatures(swComp As SldWorks.Component2, nLevel As Long)
    Dim swFeat As SldWorks.Feature
    Set swFeat = swComp.FirstFeature
    TraverseFeatureFeatures swFeat, nLevel
Sub TraverseComponent(swComp As SldWorks.Component2, nLevel As Long)
    Dim vChildComp                  As Variant
    Dim swChildComp                 As SldWorks.Component2
    Dim i                           As Long
    For i = 0 To nLevel - 1
    Next i
    vChildComp = swComp.GetChildren
    For i = 0 To UBound(vChildComp)
        Set swChildComp = vChildComp(i)
        Debug.Print sPadStr & "+" & swChildComp.Name2 & " <" & swChildComp.ReferencedConfiguration & ">"
        TraverseComponentFeatures swChildComp, nLevel
        TraverseComponent swChildComp, nLevel + 1
    Next i
Sub TraverseModelFeatures(swModel As SldWorks.ModelDoc2, nLevel As Long)
    Set swFeat = swModel.FirstFeature
