routing 101.....
Question asked by David Matula on Jul 20, 2017
Latest reply on Aug 11, 2017 by Peter De Vlieger
what are the rules for routing.....
c points
r points
sketch points
in every game there are rules and if you know the rules you may be able to get a win.....
routing I do not think that I know the rules......At one time I did know the rules....but It is looking like the rules have changed.....
I got a rout that I have been trying to fix....created in 2014.....
open in 2017....sketch is all over defined.....error msg after error msg....
get it all cleaned up..
Fixed a few fittings that I have to hold positions...delete some that are just to messed up to deal with.
replace the parts that have been deleted....end up with a sketch with a piece of pipe that needs to go to a fitting....
click on the sketch point and add the relation and the fitting moves instead of the pipe....when I would think that the pipe would move instead of the fitting.
     why would the pipe move instead of the fitting....I can always right click on pipe and say remove pipe.......so then the fitting will move....
     I can always add a dim to a piece of pipe and a fitting will move.....
Rule 1.  expect the unexpected...
