When a Tol Analysis is exported, it uses a default template that is not quite report friendly. Is there a template file that I can manipulate the way this data is presented?
Sorry Derek,
I am not aware of any template that drives how the export into excel looks/behaves.
I have never actually used tol analysis before. The only reference that I could even find to the ability to export it was here:
TolAnalyst - Tolerance stack-up analysis and validation for SolidWorks
Derek, you can edit the taresult.xsl for different formatting options(C:\Program Files\SolidWorks Corp\SOLIDWORKS\data). The excel document is not editable but there is an enhancement SPR out there that you should contact your VAR's about and add your comments.
SPR 1041623 - give the user an excel based template file to edit when exporting tolanalyst results besides the taresult.xsl
anyone?
