Autonumbering Based on Operation
Question asked by Matt Bieringer on Jul 17, 2017
Latest reply on Jul 20, 2017 by Matt Bieringer
Hello all,
I am kind of stumped. I have started to make a macro that will number our op sheets based on operation number. I can currently count each op sheet which and the macro will start back at one when the operation number changes, but I cant seem to figure out how to get it to count the total number of sheets per operation then do the individual number.
    Dim swApp           As SldWorks.SldWorks
    Dim swModel         As SldWorks.ModelDoc2
    Dim swDrawing       As SldWorks.DrawingDoc
    Dim swSelMgr        As SldWorks.SelectionMgr
    Dim swNote          As SldWorks.Note
    Dim swView          As SldWorks.View
    Dim swSheet         As SldWorks.Sheet
    Dim swAnno          As SldWorks.Annotation
    Dim swSelObj            As Object
    Dim SheetCount, e, k, t As Integer
    Dim i, j, x, y          As Integer
    Dim strop               As String
    Dim strop2              As String
    Dim descriptionText     As String
    Dim SheetNames()        As String
    Dim sheets(0)           As Long
    Dim foundNote           As Boolean
    Dim ret                 As Boolean
    Set swModel = swApp.ActiveDoc
    Set swDrawing = swModel
    SheetNames = swDrawing.GetSheetNames
    swDrawing.ActivateSheet SheetNames(0)
    SheetCount = swDrawing.GetSheetCount
    If swApp.ActiveDoc.GetType <> swDocDRAWING Then
        swApp.SendMsgToUser2 "This Macro Is Only For Use On Drawing Documents!", swMbWarning, swMbOk
        End
t = 1
For e = 1 To SheetCount
strop2 = strop
    If e > 1 Then swDrawing.SheetNext
        swDrawing.EditTemplate
        Set swView = swDrawing.GetFirstView
        Set swNote = swView.GetFirstNote
        Do While Not swNote Is Nothing
            If (swNote.GetName = "DetailItem32") Then
                foundNote = True
                strop = swNote.GetText
            Set swNote = swNote.GetNext
        Loop
        t = t + 1
    If strop2 <> strop Then t = 1
    swApp.SendMsgToUser ("OP #" & strop & " : " & t)
    Next i
    swDrawing.EditSheet
Next e
swDrawing.ForceRebuild3 True
