Drawing update macro: sheet format - ok, colors (dimensions, centerlines, center marks, datum tags) - ok, drawing template - missing, colors (balloons, cut list properties note, tolerance boxes) - missing. Could anyone help?
Question asked by Wojciech Pogorzelski on Jul 15, 2017
Latest reply on Jul 15, 2017 by Deepak Gupta
Hello everybody,
I spend hours searching forums and API help for a solution and here is where I got so far.
I have a macro, combined from a few different ones, that updates drawings sheets on an open drawing. So far the macro does:
- checks if SW file is open with message box if not
- checks if SW drawing is open with message box if not
- updates a sheet format on all sheets by removing an old one and loading a new one (a3 - iso.slddrt)
- updates colors for: dimensions, centerlines, center marks, datum tags
- saves the file
*macro works only on an active drawing.
Next thing I would like to add is an drawing template change/update based on whether the drawing was created from a part model nor assembly.
Generally I use one sheet format for all the drawings except I have two different templates: one for assemblies and one for parts.
I wasn't able to get even close to what I need with this problem.
Could anyone help me with that?
I'm also having trouble with a color change of some other features on a drawing like:
- balloons (Balloon - not working)
- annotations=>cut list properties note only (Note - works for all the notes)
- tolerance boxes (Gtol - not working).
'Colors in RGB:
'Black (0, 0, 0)
'Blue (0, 0, 255)
'Green (0, 255, 0)
'Cyan (0, 255, 255)
'Red (255, 0, 0)
'Magenta (255, 0, 255)
'Yellow (255, 255, 0)
Option Explicit
Dim swApp                       As SldWorks.SldWorks
Dim swModel                     As SldWorks.ModelDoc2
Dim swDraw                      As SldWorks.DrawingDoc
'Sheet format update:
Dim swSheet                     As SldWorks.Sheet
Dim vSheetProps                 As Variant
Dim vSheetName                  As Variant
Dim vTemplateName               As Variant
Dim longstatus                  As Long
Dim longwarnings                As Long
Dim nErrors                     As Long
Dim nWarnings                   As Long
Dim i                           As Long
'Colors update:
Dim swView                      As SldWorks.View
Dim swCenterLine                As SldWorks.Centerline
Dim swCenterMark                As SldWorks.CenterMark
Dim swDispDim                   As SldWorks.DisplayDimension
Dim swDispGtol                  As SldWorks.Gtol
Dim swDatumTag                  As SldWorks.DatumTag
Dim swNote                      As SldWorks.Note
Dim swBalloon                   As SldWorks.BalloonStack
Dim swAnn                       As SldWorks.Annotation
On Error Resume Next
Set swModel = swApp.ActiveDoc
'Is SW file open?
If swModel Is Nothing Then
    swApp.SendMsgToUser2 "                     SheetFormat Update" & vbNewLine & "" & vbNewLine & "                            Otwórz plik!", swMbWarning, swMbOk
    Exit Sub
'Is SW drawing open?
If swModel.GetType <> swDocDRAWING Then
    swApp.SendMsgToUser2 "                     SheetFormat Update" & vbNewLine & "" & vbNewLine & "                         Otwórz rysunek!", swMbWarning, swMbOk
    Exit Sub
Set swDraw = swModel
'Sheet format update (a3 - iso.slddrt)
    vSheetName = swDraw.GetSheetNames
    For i = 0 To UBound(vSheetName)
        swDraw.ActivateSheet vSheetName(i)
        Set swSheet = swDraw.GetCurrentSheet
        'Get the current drawing sheet format from this sheet
        vTemplateName = swSheet.GetTemplateName
        vSheetProps = swSheet.GetProperties
    'Sheet format delete:
    swModel.SetupSheet5 swSheet.GetName, swDwgPapersUserDefined, swDwgTemplateNone, vSheetProps(2), vSheetProps(3), True, "", vSheetProps(5), vSheetProps(6), "Default", True
    'Sheet format load:
    swModel.SetupSheet5 swSheet.GetName, swDwgPapersUserDefined, swDwgTemplateCustom, vSheetProps(2), vSheetProps(3), True, "a3 - iso.slddrt", vSheetProps(5), vSheetProps(6), "Default", True
    swDraw.ViewZoomtofit2
'Colors update
Set swView = swDraw.GetFirstView
    Do While Not swView Is Nothing
        '(DisplayDimension) - color replacement
        Set swDispDim = swView.GetFirstDisplayDimension
        Do While Not swDispDim Is Nothing
            Set swAnn = swDispDim.GetAnnotation
            swAnn.Color = RGB(0, 0, 255) 'color in RGB or...
            'swAnn.Color = 16711680 'color in decimal
            Set swDispDim = swDispDim.GetNext
        Loop
        '(CenterLine) - color replacement
        Set swCenterLine = swView.GetFirstCenterLine
        Do While Not swCenterLine Is Nothing
            Set swAnn = swCenterLine.GetAnnotation
            swAnn.Color = RGB(128, 0, 0) 'color in RGB or...
            Set swCenterLine = swCenterLine.GetNext
        Loop
        '(CenterMark) - color replacement
        Set swCenterMark = swView.GetFirstCenterMark
        Do While Not swCenterMark Is Nothing
            Set swAnn = swCenterMark.GetAnnotation
            Set swCenterMark = swCenterMark.GetNext
        Loop
        '(DatumTag) - color replacement
        Set swDatumTag = swView.GetFirstDatumTag
        Do While Not swDatumTag Is Nothing
            Set swAnn = swDatumTag.GetAnnotation
            Set swDatumTag = swDatumTag.GetNext
        Loop
        '(Balloon) - color replacement - NOT WORKING
        'Set swBalloon = swView.GetFirstBalloonStack
        'Do While Not swBalloon Is Nothing
            'Set swAnn = swBalloon.GetAnnotation
            'swAnn.Color = RGB(0, 0, 255) 'color in RGB or...
            'Set swBalloon = swBalloon.GetNext
        'Loop
        '(Note) - color replacement - NOT WORKING (works for all the notes, need only for annotations=>cut list properties note)
        'Set swNote = swView.GetFirstNote
        'Do While Not swNote Is Nothing
            'Set swAnn = swNote.GetAnnotation
            'swAnn.Color = RGB(128, 0, 0) 'color in RGB or...
            'Set swNote = swNote.GetNext
        'Loop
        '(Gtol) - color replacement - NOT WORKING
        'Set swDispGtol = swView.GetFirstGTOL
        'Do While Not swDispGtol Is Nothing
            'Set swAnn = swDispGtol.GetAnnotation
            'Set swDispGtol = swDispGtol.GetNext
        'Loop
        Set swView = swView.GetNextView
    Loop
Next i
    swDraw.ActivateSheet vSheetName(0)
    swDraw.ForceRebuild3 False
Set swDraw = Nothing
