Is there a method to project a sketch onto a curved surface with multiple faces so that the extrude cut feature can be used.
Question asked by Meredith Owen on Jul 13, 2017
Latest reply on Jul 14, 2017 by Meredith Owen
Using an offset plane, I have been able to extrude cut a sketch into the curved surface using the Offset from Surface option. However, when I attempt to change the draft angle for the cut, the draft angle starts from the plane and not the surface. Is there a way around this so that the draft angles start at the surface? Thanks in advance!
