This is a follow up on an original question in which I asked if this part could be created in Solidworks......obviously it can.
I could not upload the previous file with my post......so here's the sheet metal part.
When I use the unfold feature to edit the part, I see a nice flat pattern, but there are small unwanted tabs extending from the end of the part in the flat pattern itself.
The sketches I've made on the ends of the part must be faulty somehow.
Ideas?
sorry nick I meant check normal cut when you look at cut extrude 5 & 7 make sure it goes thru part both directions
