I have a group of parts that have a large number of configurations in each file (1350 configurations). Each configuration is set up with a specific description, and then there is a different default description.
I'm trying to get it set up so that all 5 parts will show in the description in the default configuration. In the attached image, the first 3 highlighted parts are showing descriptions from the first part with an assigned part number, and the last 2 parts are showing the default configuration descriptions.
I know there's an option in Display for setting focus to the active configuration, which in our case is not selected.
I may not be following fully, but are you just wanting a generic description for the part to be guaranteed to show in the explorer column?
If so, the @ configuration is the one that drives everything. It looks like you probably typed the ".Default" yourself. Use the @ configuration on the data card and this will drive the description logic for what appears.
Hope that helps, sorry if that isn't 100% what you meant.
