I am in the design process.... I am looking for some help. First issue is I have been asked to design the part with with 30 hits. The next issue is one side hits the same point for each of the 30 hits. I am looking for something that I could adjust the degree for every bend with one entry. I hope that this makes sense to you, if not please slap me and I will try to explain again.
Tim
Do you have to Reverse Engineer this part?
Yes you can add a different value per bend, but you will have to edit every dimension..
