I have successfully wrapped to a curved surface but I cannot get this to wrap to a conical surface as you will see from the part. I would like the sketch on top of the part to show on the lower conical surface if this is possible.
Thanks, Daniel.
Thanks, Daniel.
Daniel, you could try creating a surface (Insert > Surface > Extrude) and then doing either a Split Line (Insert > Curve > Split Line) or an Intersection Curve (Tools > Sketch Tools > Intersection Curve).
Note: After doing this, you may want to do a Body Delete / Keep to eliminate remaining surface features (Insert > Features > Delete / Keep Body)
